Go Back   Pontiac GTO Forum | GasTiresOil.com > GTO Technical Forum > Wheels and Tires
Old 02-28-2012, 07:32 PM   #1
New Centercaps
Just a sneak preview...
Modified Pontiac Solstice centercaps. The camera flash makes it look a different color than the wheel but they're actually very close. And with my chrome lugnuts, I think it will look nice and add a very subtle touch.
EDIT: The finished product:
Edit 2/18/2014. I decided to go with the G6 centercaps which are identical but have a red arrowhead:
Old 02-28-2012, 11:13 PM   #2
Rabs
Go Spurs Go!
Rabs's Avatar
So far so good. I like the look. Way to get creative!!!
2006 Impulse Blue/Blue M6 - Brunhilda
Rabs is offline   Reply With Quote
Old 02-29-2012, 08:09 PM   #3
I think I just found my center caps for when I chrome out my stock 18s.
Old 02-29-2012, 10:30 PM   #4
nebo
giggity, i like
Mod List Link
2006 TR M6 - Stock Block @ 629HP / 608TQ with Harrop HTV1900 and support mods in the link above
1999 Chevrolet Metro Chalkboard Black M5 - Stock Block @ 52HP / 47TQ with 12 Wheels, 0.75in Exhaust Tip, and a Bubble Machine Become a fan of my Metro Facebook Page http://www.facebook.com/pages/Chalkb...80878071978607
nebo is offline   Reply With Quote
Old 03-28-2012, 09:41 PM   #5
Looks good Robo.... have you thought about painting the arrow head red and then some clear over the top of it all?
Old 03-28-2012, 09:58 PM   #6
I'm probably going to leave them plain for now.
Old 03-28-2012, 10:02 PM   #7
Cool, im in for pics when its done...
Old 04-04-2012, 11:21 PM   #8
OK - here's the centercaps. These are Pontiac Solstice centercaps. I broke off the black plastic fingers on the back since they don't work with the GTO wheel. I then JB Welded them to these metal plugs I found at Home Depot. These plugs are for plugging holes on electrical boxes but have metal tabs that can be bent to make them snug in the GTO wheels.
Name:	2012-04-04 at 17-34-08.jpg
ID:	1237   Click image for larger version
Name:	2012-04-04 at 19-18-51.jpg
Old 04-04-2012, 11:27 PM   #9
Nice Robo thats a good idea...
Old 04-21-2012, 05:33 PM   #10
Where did you get them?
Old 04-23-2012, 03:23 AM   #11
Zinn
B.O.H.I.C.A.
Zinn's Avatar
Nice ingenuity. Hopefully that JB weld holds up for you.
Zinn is offline   Reply With Quote
Old 04-23-2012, 08:07 AM   #12
From GMPartsHouse.com. $7 each.
Old 04-23-2012, 10:59 AM   #13
OldGoat
This might be a good fix for the stock center caps when the tabs break on them.
OldGoat is offline   Reply With Quote
Old 05-18-2012, 11:29 PM   #14
New centercaps installed:
Name:	2012-05-18 at 19-52-56.jpg
ID:	1292   Click image for larger version
Name:	2012-05-18 at 19-53-56.jpg
ID:	1293   Click image for larger version
Name:	2012-05-19 at 12-13-23.jpg
ID:	1294   Click image for larger version
Old 05-28-2012, 12:17 AM   #15
Just FYI - I have put over 500 miles on the GTO since I installed these new centercaps. No problems whatsoever and they haven't come loose at all. I'm very pleased with how they turned out.
Old 09-28-2012, 03:53 PM   #16
Still no problems with the centercaps coming loose or anything. Got a lot of compliments on these at Goatfest, too.
Old 10-01-2012, 02:22 PM   #17
Rabs
Go Spurs Go!
Rabs's Avatar
They do look DAMN GOOD!
Old 10-11-2012, 07:44 PM   #18
opmiii
opmiii's Avatar
Very nice indeed!!!!!!!
opmiii is offline   Reply With Quote
Old 02-18-2014, 11:37 PM   #19
After giving it some thought, I decided to go with the G6 centercaps that have the red arrowhead. They are identical to the Solstice caps except the arrowhead is red. Making them work was identical to how I made the Solstice caps fit.
Old 02-26-2014, 03:24 PM   #20
Stoopalini
I really like those wheels man, and the caps look great! Did you get the wheels from JHP?
2005 - M6 - QSM / Black
100% Poly / Lou's SS / SLP Rear Sway
Cluster Programming Sheet
Stoopalini is offline   Reply With Quote
Copyright ©2000 - 2022, vBulletin Solutions, Inc.
