Go Back   Pontiac GTO Forum | GasTiresOil.com > GTO Technical Forum > Brakes and Suspension
Old 04-02-2010, 06:07 PM   #1
nexstar7
steering wheel shake
i put on some new after market rims. now at around 58 to 62 the steering wheel shakes. its balanced 5 times , that includes road force balancing. what could it be. rims, tie rod? i didnt have the shakes with the original rim. anybody know anyone in queens or long island for a little help?
nexstar7 is offline   Reply With Quote
Old 04-02-2010, 06:29 PM   #2
wayfastwhitey87
wayfastwhitey87's Avatar
Did you put hub rings on? I had a shake in my steering after being balanced 3 or 4 times I bought a set of hub rings and the shake went away.
wayfastwhitey87 is offline   Reply With Quote
Old 04-02-2010, 06:59 PM   #3
nexstar7
yup, they put hub rings. ive been back and forth for 3 weeks.its killin me
Old 04-28-2010, 08:36 AM   #4
DNTMPME
Flohrit
Send a message via Yahoo to DNTMPME
I bought some wheels from Brazen2006 and he said he had a shimmy up front. He used the hub rings and when we put them on my car I couldn't get the hub rings to slide on, even after sanding on the hub. I decided to run the wheels without the rings. I was very careful when I tightened the lugs down. I tightened them down indiviually by hand first then used the lugs wrench. I have no shake or shimmy at any speed. I know they say not to run them without rings since these cars are hub bearing cars, but I have had my method work for me with no problems. This is just my opinion though...
It's not stock
DNTMPME is offline   Reply With Quote
Old 04-28-2010, 08:54 PM   #5
PartsGedder
Pedders USA Warehouse
Have you tried swapping the fronts to rears to see if its in the wheels or the hubs? You can also try pulling the wheel, then pulling the rotor and moving it 2 position clockwise and then putting the wheel on 3 positions clockwise to see if the vibration changes. This can help narrow it down to rim or hubs.
Dan Morris
Pedders USA
PartsGedder is offline   Reply With Quote
Old 05-31-2010, 05:16 PM   #6
QSGTO
I'll never pay 4 a 4um
QSGTO's Avatar
I have the same problem with my aftermarket rims. It got so bad that it cracked the P/S line where it goes into the rack and pinion. Cost me $50 for a new line assembly.
Blue
_______FINISH_______
________________________________
QSGTO is offline   Reply With Quote
Old 07-24-2010, 07:59 PM   #7
Lspwr
Tubbed!!
Lspwr's Avatar
May be a tie rod end issue if you've rotated front to rear w/ the same problem reoccuring.
Lspwr is offline   Reply With Quote
Old 07-25-2010, 12:06 AM   #8
one thing to look at, some folks don't properly torque the lug nuts, they over torque them using a impact etc. Easily warping the rotors.
mods.... yep I've done them!
427 TVS2300 Killer Chiller Meziere ETP 245 Lonnie's twin pump system Hendrix-Engineering two piece driveshaft and custom radiator. LSPWR mini tubbed with 315's. Converted from M6 to a 4L80E built by FLT Yank SC3000
tom's2005gto is online now   Reply With Quote
Old 07-25-2010, 12:10 AM   #9
Lspwr
Tubbed!!
Lspwr's Avatar
Very true. . . I was giving O.P the benifit of the doubt, but I guess it is indeed something that needs to be mentioned in trying to narrow down a cause for front end shakes.
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
